VSC Light
Old Jul 22, 2007 | 01:19 PM
toolman_ar's Avatar
Default VSC Light
My car is a 1999, LS400 with 167,000 miles. I had the front rotors replaced three weeks ago. Since that time there has been a noise similar to a bearing going bad, but only happens when the breaks are applied. I guessed it was just the old pads working into the new rotors.
Two days ago the car died while comming to a stop. The car restarted but the Check VSC light was on. I drove for two hours and had no problem. When I stopped for fuel and restarted the car the light whent off.
Today while sitting in a drive through line I noticed the radio shutting off when I pressed the break pedal. It did this four to five times and then the car shut off. When I restarted the car the VSC light was back on.
I am going to pull the tires and inspect the front breaks to see if there is anything out of the ordinary, any ideas???
Old Jul 23, 2007 | 11:39 AM
rexpak's Avatar
Default RE: VSC Light
you might have an electrical problem.... if you can go to autozone they can run free diagnostics for you and tell you whats wrong with your car....
halexus
Jul 29, 2021 12:05 PM
rx300 girl
Mar 3, 2021 12:34 PM
joycewal
Jun 15, 2010 08:40 PM
bevans
Jun 14, 2006 02:41 AM
m3amg43
Dec 22, 2005 02:46 PM
