How to Convert MTS/M2TS to iTunes on Mac
Old Sep 4, 2012 | 12:30 AM
windyjhzt's Avatar
Default How to Convert MTS/M2TS to iTunes on Mac
If you want to import MTS/M2TS videos to iTunes and then sync to your
Apple devices, problems will come out. As we know, MTS/M2TS is in AVCHD format which is a high-definition format used by Sony, Panasonic, and
other HD camcorders. This kind of HD video format is compatible with few media players and applications. iTunes is an Apple application which also
accitune iconepts few video and audio formats such as MOV, MP4, MP3 and so on. If you need to load MTS/M2TS video to iTunes, you have to convert
it to iTunes supported format.
Video Converter for Mac is an excellent program which could help you convert MTS/M2TS to iTunes at ease. It is an multi-functional and easy-to-operate software which supports to convert virtually all video
and audio formats on Mac with high efficiency. You can also edit the videos with various powerful editing tools. Safely download the program and
try to find the powerful functions from below tutorial.
How to make MTS/M2TS to iTunes conversion on Mac?
Note: This tutorial is for Mac users. If you are a Windows user, you can go to the Video Converter for Windows guide for more information.
Step1. Load files into this MTS/M2TS to iTunes Converter
Launch Video Converter for Mac, you can click "File" item on the tool bar to load files or simply drag files in. To save your time, batch
conversion is supported.
mac video converter main interface
Step 2. Select the correct output format
Because M4V, MP4, MOV are supported by iTunes, you can click "Format" options in the "Output Setting" menu, and then go to "Common Video" category
to choose them as your destination format. Of course, if you want to sync to Apple devices, you can also go to the "Apple Devices" catogory and
select the correct output profile.
mac video converter mts to itune output format interface
Step 3. Start MTS/M2TS to iTunes conversion on Mac
After all the settings, please click "Convert" button on the bottom right, and then all the tasks will begin at fast speed and high quality.
More features on mts to itune Converter:
1. You can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu to make
the output video better. If no need, you can just keep the default parameters.
2. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep",
"Shut down my computer" and "Do nothing" three mode options.
3. Before MTS/M2TS to iTunes conversion, you can edit the video with its customized features.
Go to "Trimming" section, please click the scissors icon, you can move the sliders on the player bar or input the exact time index by yourself to
determine the length.
Go to "Cropping" section, move the limiters of the dashed frame on the player window to remove black margins.
Go to "Video Adjustment" section, move the handlers to modify video brightness, contrast, saturation and audio volume.
Go to "Subtitle" section, you can choose “Load Subtitle” option in the Subtitle item to load video related subtitles.
Go to "Watermark" page, select an image or text file and use the positioning sliders to locate it on screen.
windyjhzt
Sep 7, 2012 12:09 AM
windyjhzt
Sep 5, 2012 10:32 PM
windyjhzt
Sep 5, 2012 12:09 AM
windyjhzt
Sep 3, 2012 12:45 AM
windyjhzt
Aug 30, 2012 02:08 AM
