Sunroof Motor replacement '01 LX 470
Looking for suggestions!
My wife has a sunroof motor that died slightly open, so it leaks when it rains or snows. I've had it taped for the last few years, but tonight I thought I'd try to take out the motor to possibly get a replacement and manually close the sunroof. It looked easy enough to pop out on the youtube videos, although taking it out in reality was quite different. I removed the sunglass/light assembly to expose the motor and unscrewed the nessessary 10mm bolts, but I just couldnt get the sucker out. Is this one of those situations where I have to remove the entire head liner? I'm not sure if I'm missing a bolt or if this motor is locked in a certain way that is not described in the videos. I'm considering just caulking the whole window full of silicone so I can be done with it, but if I can figure out how to take out the motor to fix the seal I'd much rather do that. |
| All times are GMT -5. The time now is 08:39 AM. |
