LS400 Wont start!
Hello everyone i'm new to this forum but i've been reading it's helpful threads for a while now. I have a 92 LS400 and i was trying to remove code 25 (02 sensors) i installed universal ones and the code stayed on and then code 52 (knock sensor) came on. later i changed the roters and distributor cap and in the process dropped a wrench on the battery post and the barttery sparked for about 15 seconds, after that my LS400 would hesitate horribly and i noticed that my horn works sometimes now. I then changed the knock sensor and starter. The car then came on but when i step on the gas it shuts off and has not came on since. the fuses under the hood and steering column dont look blown. Gas is being pumped from the fuel pump and the plugs are firing, anyone have any ideas? I REALLY NEED A HAND HERE.:confused:
Here are some things ive changed in the order they were changed but the car still wont start: both Oxygen Sensors, both Rotors, driver side Distributor Cap, PCV Hose, Mass Air Flow Sensor, Spark Plugs and Wires, ECU, Fuel Filter and ECT sensor. |
| All times are GMT -5. The time now is 04:46 AM. |
