91 LS wrecked - now have a transmission problem
OK, on a 1991 LS400 that was in a front end collision, now the car will not go into park. Car cranks and runs. I have not moved it around as the radiator was punctured and I'm concerned about damaging things. It will shift reverse, neutral, drive, etc, but will not go into park. I was told that it may have a neutral lock out switch as a safety if in a collision. Does this sound right?
Any help would be much appreciated.
Thanks,
Donald
Thanks,
Donald
sounds bad so you just have to bring it for a mechanic check..my own problem was about my cooling system leaking and had changed its lexus radiator buy..a routine maintenace is imp0rtant to prolong its life-span..be sure to have your manual as a guide to0.
