Low Oil Pressure warning 2002 es 300
Old Dec 8, 2009 | 09:03 AM
parker525's Avatar
Default Low Oil Pressure warning 2002 es 300
I have a 2002 ES 300, today the low oil pressure warning light came on. everything sounds normal no tapping / overheating. I changed the oil and filter in case something clogged it,but it is still on. I know as an engine wears the pressure will drop as the worn areas allow more oil to pass. What next, I am concerned about damaging the engine.
Old Dec 28, 2009 | 07:25 AM
Gabring09's Avatar
Hi everyone,
I just changed my oil and now when I start the engine, I get the low oil pressure indicator and oil light. Once I drive the car, it goes away.
Also, I have a burnt out bulb in my temp control in the dash. How do I replace the bulb?
Old Dec 29, 2009 | 01:12 AM
Pyroisp09's Avatar
Double gasket on the oil filter. A valve cover will not "shoot" oil do to lack of oil pressure under the cover. If you just had the oil changed its most likely to problem.
jken0904
Jul 25, 2021 02:41 PM
MollysPapa
Mar 3, 2021 02:07 PM
Shelly Parks Graham
Mar 3, 2021 11:52 AM
boli1021
Jan 6, 2008 11:55 PM
1994sc300
Sep 11, 2007 10:32 PM
