1990 ES250 starting problem
Hi
I have a 1990 Lexus ES250. The starter makes a clicking noise when I try to start it.
I replaced the starter and the battery. The problem is still there about a click every second when I turn the key.
The car has an automatic transmission. Does this car have a starter relay? If so where is it located?
I reviewed the wiring diagram for a 1990 Camry, not sure if they are the same and the Camry only has a starter relay for the manual transmission cars. I called the lexus dealer and they do list a starter relay for this car. I believe the car only came as an automatic.
So I would like conformationifthe lexus ES250 1990 manual trans hasa starter relay, and if so, would liketo investigate it, does anyone know where it is located?
Thanks
Thanks
Cpt Marvel
Jul 22, 2008 08:18 AM
