How-To: Replace the starter on a is300
Old Jul 29, 2011 | 12:30 PM
lexicon's Avatar
Default How-To: Replace the starter on a is300
Hey guys!
For those of you who own a is300 in need of a new starter, don't take your car to the dealership and get subsequently get reamed on labour charges. Here is a succinct write-up on replacing the starter on a is300:
--Reference Materials--
IS300 starter diagram
--Remove or disconnect the following--
Negative cable
Starter connector
Nut, and disconnect the starter wire
2 bolts and starter
--To install--
Installation is the reversal of the removal procedure.
Tighten the starter bolts to 27 ft. lbs. (37 Nm).
Remove or disconnect the following:
Negative battery cable. Wait at least 90 seconds before performing any other work
Starter connector
2 bolts and starter
--To install--
adbbqwi
Jul 25, 2021 03:23 PM
murphysf
Jul 25, 2021 03:22 PM
emanul2000
Aug 8, 2020 03:50 PM
jes172
Aug 24, 2008 06:06 PM
samkhan111
Apr 21, 2005 10:21 PM
