How-To: Replace the starter on a is300
Hey guys!
For those of you who own a is300 in need of a new starter, don't take your car to the dealership and get subsequently get reamed on labour charges. Here is a succinct write-up on replacing the starter on a is300: --Reference Materials-- IS300 starter diagram --Remove or disconnect the following-- Negative cable Starter connector Nut, and disconnect the starter wire 2 bolts and starter --To install-- Installation is the reversal of the removal procedure. Tighten the starter bolts to 27 ft. lbs. (37 Nm). Remove or disconnect the following: Negative battery cable. Wait at least 90 seconds before performing any other work Starter connector Nut, and disconnect the starter wire 2 bolts and starter --To install-- Installation is the reversal of the removal procedure. Tighten the starter bolts to 27 ft. lbs. (37 Nm). |
