How to reset the warning light
I just did the oil change on my 2005 Rx330 (20,600 miles) & I couldn't figure out how to reset the warning lights which says 'maintanace required'. can anyone guide me in this regardwith thanx
Arcot T
The system must be reset after the engine oil replacement. Reset the system by the following procedure:
Turn the ignition key to the "LOCK" position with the odometer reading shown.
Turn the ignition key to the "ON" position while holding down the "ODO/TRIP" button. Hold down the button for at least 5 seconds. The odometer inidcates "000000" and the light goes off. If the system fails to reset, the light will continue flashing.
good luck, kendog
good luck, kendog
robertwagner
May 18, 2007 10:58 AM
