How do you Reset the Maint Reqd Light?
Please Help!! How do you reset the Maint Reqd light for the oil change? I change oil myself because the Dealer is way too expensive. Please Help anyone.
Originally Posted by Kbfgskbfo
(Post 42608)
I'm not sure what model you own but here is a general write-up on turning off that annoying light: 1. Turn ignition switch to the ON position. 2. Set the Odometer / Trip Display to the ODO mode 3. Turn the ignition switch to the OFF position. 4. Depress and HOLD the Trip Meter RESET button while turning the ignition switch to the ON position. 5. The Service Maintenance Reminder Light will: a. Illuminate solidly for 3 seconds. b. Blink for 2 seconds. c. Illuminate solidly for 1 second. d. Turn off. 6. Release the Trip Meter RESET button. 7. Turn the ignition to the OFF position. 8. Turn the ignition to the ON position, and confirm that the Service Maintenance Reminder Light goes out. NOTE: If the light continues blinking in step 5a, turn the ignition off, and repeat the procedure from step 1.ignition off, and repeat the procedure from step 1. |
Originally Posted by lexicon
(Post 42645)
Hello,
| All times are GMT -5. The time now is 05:42 AM. |
