90 ls400 need help
Old Dec 4, 2008 | 06:39 AM
tinocolj's Avatar
Default 90 ls400 need help
hit a big sink hole or road was just built that way. did not loose control and car did not bottom out, but my speed gauge did go from 80mph to zero and hasn't worked since then. have read that the problem is a speed sensor.is that correct? any other ideas? if correct where would it be located?
rear brake caliper on driver side- can it be compressed with a c-clamp like on the passenger side?yeah it probably is stuck, just need a second opinion.
thanks for any help
Old Dec 11, 2008 | 07:58 PM
remember the name's Avatar
Default RE: 90 ls400 need help
#1 are you talking about the "wheel" speed sensor? if so it can be foun be folwoing the black wire from the wheel well to the contorle arm to the brake dust shield and it should be a black and snaped on.
#2 yes it can.
Autogeek.net
Oct 8, 2013 09:53 AM
Doherty17
Dec 5, 2010 04:36 PM
tinocolj
Dec 5, 2008 02:32 AM
Squeeky
Feb 17, 2006 11:00 PM
Schiavoni
Jul 22, 2005 04:42 PM
