1990-1994 Lexus LS400 problem
Old Sep 9, 2009 | 09:38 PM
lovely09's Avatar
Default 1990-1994 Lexus LS400 problem
What are the common problems associated with a 1990-1994 Lexus LS400?
Power Steering pump leaking/failure is a common problem. Brakes are not the best on this car. Do not "power flush" the transmission when changing transmission fluid. Throttle body should be cleaned every 100,000 miles. Engine on this car is strong.
Old Oct 4, 2009 | 09:54 PM
jbgillick's Avatar
Thumbs down Steering pump leak
I have a 1995 SC400 that has a steering pump or hydraulic line leak. It is hard to get at the pump to remove it in order to find the leak spot and inspect the line. jbgillick@embarqmail.com
Old Oct 18, 2009 | 01:21 AM
lovely09's Avatar
What did you do in order to find the pump?You have to reach the pump and inspect if there's leak to address the problem properly.
Old Oct 29, 2009 | 10:56 AM
ted27's Avatar
what do you mean by throttle....i am not very clear about this ...can you explain...
Old Nov 1, 2009 | 02:33 AM
  #5
bryanchan's Avatar
i don't get you either.. please elaborate more.
murphysf
Jul 25, 2021 03:22 PM
kimmy95620
Mar 3, 2021 11:00 AM
ST LUCIE APPRAISAL
Oct 13, 2009 05:33 PM
murphysf
Oct 9, 2007 01:16 PM
ruskibusiness
Mar 7, 2007 04:02 PM
