Navigation System Secret Code
I just got a new 2007 RX400H with Navigation. I'm told it has the latest Navigation version - seventh edition. When driving, certain functions of the NAV system are disabled for safety until you come to a complete stop. My dealer gave me a code that should disable this safety feature but it appears to be for the previous NAV version.I'm all for safety but if you are a passenger in the car you shouldn't have to wait until you are stopped to use all the features.
Anyone know how to disable this? |
RE: Navigation System Secret Code
WHAT IS THE CODE FOR THE PREVIOUS VERSION.?
LATEST VERSION IS A 6.1
Go to the Volume screen, then touch the screen in the following sequence:
Upper Left Lower Left Upper Left Lower Left You'll get a special screen, touch and hold OVERRIDE until the system beeps. This will allow you to enter/change anything to do with the NAV system while in motion. It unfortunately resets itself after each restart of the car and does NOT work on the audio or others sytems. |
What about the voice commands ??? Anything you can do with the touch screen you can do with the voice commands ...... not sure of the commands???? "Help" always brings up the exact wording of each command and what it does............
[sm=pcwhack.gif] Just my $0.02 worth..... |
I tried the code provide by user: daveinMA but had no success. The screen did not respond with any menu or button and regardless of how I touched the screen it didn't work. Could it be that the 2007 hybrid model has a different version of the NAV system? Anyone else have any ideas?
ORIGINAL: hybrid I tried the code provide by user: daveinMA but had no success. The screen did not respond with any menu or button and regardless of how I touched the screen it didn't work. Could it be that the 2007 hybrid model has a different version of the NAV system? Anyone else have any ideas? http://www.coastaletech.com/ It's guarenteed to set your system right.......... Good Luck, If the Mechanics come up with anything then I'll let you know............. T Quinn;) |
Thanks, my other car had the same problem
ORIGINAL: hybrid I'm all for safety but if you are a passenger in the car you shouldn't have to wait until you are stopped to use all the features. Anyone know how to disable this? |
All look into this and get back to everyone.
| All times are GMT -5. The time now is 04:29 AM. |
