Wheel and Tires Discuss anything Wheel and Tire related here.
Aftermarket TPMS for Lexus
Old Oct 22, 2015 | 08:29 AM
carid's Avatar
Former Sponsor
Default Aftermarket TPMS for Lexus
If you are buying new rims or tires for your car - don't forget about the TPMS sensors. A lot of modern vehicles are equipped with these little devices that make our life easier,
so it is needed to maintain and replace them when necessary.
Aftermarket TPMS sensors are often many times cheaper than OE sensors and designed to work with pretty much any kind of wheels. Here at CARiD we offer sensors that fit over 90%
of the vehicles on the road. They program for your vehicle using the exact same procedure as you would use for the factory sensors. Be proactive, properly inflated tires save money
due to better fuel efficiency, they are safer and last longer.
There is a reason why the TPMSs are mandatory, they are essential for safety, will provide you with better fuel efficiency and maximize the life span of your tires. Don't forget to replace
your sensors when mounting new tires; this way you won’t have to pay to have the tires remounted and balanced again if the sensors fail shortly afterwards. If you have 2 sets of wheels
for summer and winter use - just get an extra set of TMPS sensors and forget about switching them from one set to another.
Note: If you’re buying new wheels from us, order the TPMS sensors at the same time. We’ll install them, and mount and balance the tires before we ship them to you.
Doing regular vehicle maintenance is one of the keys of safety on the road. Check out our wide selection of TPMS sensor here: TPMS Sensors | Tire Pressure Monitoring System - CARiD.com
Also read more about ORO-TEK Products at CARiD. They offer a drop-in replacement for OEM TPMS sensors, and will link to your vehicle’s TPMS system in the exact same manner as the original units.
Stay safe!
Galager
2
Dec 4, 2010 11:01 PM
redcarwire
Jun 29, 2010 09:51 AM
angelina
Oct 3, 2007 10:44 PM
