Sights N Sounds post all of your video and sound clips here.
So, my 99 GS300 started running rough out of no where.
Old 02-12-2019, 09:28 PM
Laqintin's Avatar
Default So, my 99 GS300 started running rough out of no where.
I've replaced spark plugs, spark plug wires, coils , everything to do with spark plugs. Just the other day I got a misfire codes (P0300, P0305). I tried checking the spark plugs and found out that cylinder 5 and 2 were the problem because when I pulled the wire away from the spark plug there was no difference in the idle. I cleaned and sprayed all the spark plug holes with brake cleaner. I think I fixed it but once I put everything back together the idle was tougher than before. When I put the car in drive, the idle almost gets to the point that the car is going to die. Any suggestions?
rasheed52479
02-04-2008 11:31 AM
jwandhistools
01-28-2008 07:34 PM
Sparkplugs.com
12-01-2006 03:47 PM
Sparkplugs.com
12-01-2006 03:45 PM
Quick Reply: So, my 99 GS300 started running rough out of no where.
