XTruck USB Link + 125032 Software Diesel Truck Interface
XTruck Support Heavy-Duty, Light-and Medium-Duty Trucks, CONSTRUCTION EQUIPMENT like (Wheel loader, Articulated Hauler and
Excavator), Genset.. Compatible with applications that diagnose engines, transmissions, ABS, instrument panels and more. XTruck USB Link + Software Diesel Truck Interface and Software with All Installers Attention: It Can Not Be Updated ! Xturck USB Link + Software Diesel Truck Interface Supported Languges For Volvo, Hino, Cat and Nissan software,please install them on Windows XP only,other vehicle softwares can be installed on Win 7. When you change time of your laptop, Cummins Inline software will get locked, please download the attached file “how-to- unlock-cummins-inline" to solve it. XTruck Features: Compatible with applications that diagnose engines, transmissions, ABS, instrument panels and more. Reduce reprogramming times with direct USB connection Mixed fleet capabilities with broad protocol support Quick access to vehicle data for maintenance or management reports Quickly attaches to vehicle's diagnostic connector. Easy portability increases flexibility, May be used with desktop PC or laptop. XTruck USB Link Packed Software and Application - Allison (Included!) - Bendix 6.3.8.0 (Included!) - Detroit Diesel DDDL 7.05 ((Included!) - Detroit Diesel DDCT (Included!) - Detroit Diesel Calibration Tool (Included!) - Eaton Service Ranger 3.2 (Included!) - International DLB (Included!) - International ICAP, IPTS, NETS, IPC (Included!) - International Master Diagnostic (Incluided!) - Meritor and Wabco Diagnostics (Included!) - Cummins Insite 7.5 (Included!) - Hino 2.0.2. (Included!) - Caterpillar 2.0.1.0 (Included!) - Perkins EST 2010B (Included!) - V Macks 2.6.12 (Included!) - V Macks Dealer Pro (Included!) - Volvo VCADS 2.35.10 (Included!) - Toyota Techstream for car (Included!) XTruck USB Link API Support RP1210A, RP1210B J2534-2 USB vehicle-to-PC connectivity, XTruck USB link supports Windows xp and windows 7 32-bit and 64-bit and windows CE compliant Not all applications are included. If compatibility confirmation is required, more information is needed, or there are questions about an unlisted application, please contact us, a specialist will help you make the right choice. XTruck Protocol Coverage CAN - J1939/CAN125/CAN250/CAN500/CAN1000 2nd CAN - J1939/CAN125/CAN250/CAN500/CAN1000 J1587/J1708 J1850 J2534 ISO 15765 (Diagnostic CAN) ISO 14230 (KWP2000 over ISO9141) ALDL ATEC 160 (160 baud) FREE Heavy-Duty Truck Diagnostic Applications 1 VOLVO TRUCK: FM10, NH565, FH12, FM12, VHD, FH16, FM7, VN, WC, WG, WI, FH565, NH12, FL6, FL7, FL10, FL12, NH525, WX, COMP04, FE, VHD, FH, FM, VM, FM9, F10, F12 , F16, NL10, NL12,VOLVO BUSES: B10B, B10M, B10L, B10R, M10R, B12, B58, B6, B7R, OLYMPIAN, SUPEROLY 2 VOLVO BUS: B12B,B12M,B12R,B6R,B7L,B7R,B9L,B9R,B9S,B9TL,PREVH, PREVX,3,MACK TRUCKS: V-MAC I, V-MAC II, V-MAC III, V-MAC IV, Service Diagnostic 3 VOLVO CONSTRUCTION EQUIPMENT (CE): Wheel Loader: L110E, L110F, L120E, L120F, L150E, L150F, L180E, L180F, L220E, L220F, L330E, L350F, L60E, L60F, L70E, L70F, L90E, L90F Articulated Hauler: A25D, A25E, A30D, A30E, A35D, A35E, A40D, A40E, T450D, Excavator: EC135B, EC140B, EC140C, EC160B, EC160C, EC180B, EC180C, EC210B, EC210C, EC235C, EC240B, EC240C, EC290B, EC290C, EC330B, EC330C, EC360B,EC360C, EC460B, EC460C, EC700C, EC700B, EC700C, ECR145C, ECR235C, ECR305C, EW140B, EW140C, EW145B, EW145C, EW160B, EW160C, EW180B, EW180C, EW200B,EW210C, FC2121C, FC2421C, FC2924C, FC3329C, PL4611 Grader: G710B, G720B, G726B, G730B, G740B, G746B, G780B, G930, G940, G946, G960 , G970, G976, G990 4 Navistar: ALL Diamond Logic Builder (DLB) Service Maxx 5 International: ALL Intune, MD32, 6 Freightliner:ALL ServiceLink:cascadia,century,columbia,Coronado,cla ssic,FLDSD,4900FA, 4900SA, 4900EX. 7 HINO: ENGINE:300SERIES, 500 SERIES, CR03_J08E, CR03_J05D, COMMONRAIL(J05E), J05D_US, J08E_US,P11C,VCS, Hibrid, Inverter, Brake (ABS), AT_45043LE 8 ISUZU_GMC: 1996-1999 NPR Diesel and F Series Include NPR/W 3500, NPR HD/W 4500, This is for 6.0L V-8 Gasoline Engines only, 7.8L 6HK1 Engine Isuzu: NPR, NPR HD, NQR, NRR, FTR, FVR, FXR with 6HK1 LG4 Engine, NPR, NPR HD, NQR, NRR with 5.2L (4HK1) or 3.0L (4JJ1) Diesel engine. 6.0L V-8 Gasoline Engine GM: W3500, W4500, W5500, WT5500, W5500 HD,with 5.2L Diesel Engine Only,T6500,T7500, T8500 9 SCANIA VEHICLE, KOMATSU Excavator, and MAN Vehicle will be update XTruck USB-Link Works with All Popular Engines: Detroit Diesel, Caterpillar, Cummins, Perkins Engines. 1,Detroit Diesel Diagnostic Link (DDDL) All DDEC VI equipped engines,DD13,DD15,DD16,SERIES60,MBE4000,MBE900,and RS9, RSX9-A,RSX9-B, RSX9-R,RS10, RSX10 J1939 engine brake level for Series 2000 and 4000 Engines with USA and ISO firing order selection 2, Caterpillar (on high way engine for j1939) 3126, 3406, 3306B, 3512C, C4.4, C6.6 C7 C9 C11, C13 3,Cummins INSITE 4d95-cm2150c/D 6d125/6d140/6d170 B5.9g C Gas plus/B Gas plus C8.3g/L10G Gas compression GTA3.9/5.9/8.3GC, KTA19/38GC-CM556 ISB-CM2150D ISB-CM2250 ISB-CM850 ISB Daimler Chrysler ISB4.5/6.7 CM2150 ISB5.9G-CM2180 ISBe-CM850 ISBe-CM2150E ISC-CM2150D ISC-CM2250 ISC-Transit Bus ISL8.3-CM850 ISDe-CM2150C ISF2.8-CM2220E ISF2.8-CM2220S ISF3.8-CM2220 ISF3.8-CM2220S ISL-CM2150D ISL-CM2250 ISL G-CM2180A ISL8.9-CM850 ISLe4.5-CM2150E ISM-CM870 ISM-CM875 ISM-CM876 ISM11 CM876 ISX-CM871 ISX11.9/15/16-CM2250 ISX/ISZ13-CM2150 L Gas Plus PIM QSB 6.7-CM2250 QSB 3.3-CM2150D QSB4.5/5.9/6.7-CM850 QSB5/7-CM850 QSC8.3-CM2250 QSC8.3/QSL9 QSK19-CM850/CM2150 QSK19/23/45/60/78 QSK19G/45G/60G,QSV81/91 QSK23-CM500 QSK38-CM850/CM2150 QSK50/60-CM850/CM2150 QSL 9-CM2250 QSL9-CM850 QSM11-CM876 QST30-CM552 QST30-CM850 QSX15 Signature/ISX-CM870 4, Perkins Engines 1000 (6 Cyl ) / 6.354 Series RA - 6.247 Series RA - 6.247 T - 6.354 Series SOS - 6.354 Standard Option Schemes TC - 6.354 TD - H6.354 TE - T6.354 TF - HT6.354 TG - 6.354.1 TH - T6.354.1 TJ - 6.354.2 TK - C6.354.2 TP - T6.354.3 TR - 6.372 TT - TC6.354.1 TU - T6.354.4 TV - 6.372.4 TW - 6.354.4 TX - C6.354.4 TY - H6.354.4 TZ - HT6.354.4 Y - Phaser / 1006 Series YA - 6.60 YB - T6.60 YC - C6.60 YD - CC6.60 YE - T6.60CC YG - 6.601 YH - T6.601 YJ - CCA6.601 YK - CCW6.601 YS - Option Packs M225TI / M215C 1100 Series D - 1100 Series 3 Cylinder DC - 1103C-33 DD - 1103C-33T DF - 1103B-33 DG - 1103B-33T DJ - 1103A-33 DK -1103A-33T R - 1100 Series 4 Cylinder RE - 1104C-44 RF - 1104C-E44 RG - 1104C-44T RH - 1104C-E44T RJ - 1104C-44TA RK - 1104C-E44TA RR -1104A-44 RS -1104A-44T RT -1104A-44TA V - 1100 Series 6 Cylinder VK - 1106-E60TA P - 1100D Series 6 Cylinder PJ - 1106D-E66TA PO - Option Packs 1100 Series N - 1100D Series 4 Cylinder () NH - 1104D-E44T () 1300 / Peregrine Series W - 1300 Series WB - T6.466 WC - CC6.466 WD - T6.67 WE - CC6.67 WF - T6.76 WG - CC6.76 WH - T6.87 WJ - CC6.87 WK - UT6.76 HEUI WL - UCC6.76 HEUI WM - UT6.87 HEUI WN - UCC6.87 HEUI WO - 1300 Series Option Packs WP - UT6.761(I) HEUI WR - UT6.871(I) HEUI WS - UCC6.871(I) HEUI 2000 / 3000 Series 4 - 3000 Series S4B - 3008 S4C - 8M700 / 800TI Condor Marine S4E - 3008 SI 6 - 3000 Series 6A - 3012 S6A - 3012 S6C - 3012 S6D - 3012 S6E - 3012 SI 8 - 2000 Series 8B - 2006 8C - Eagle / 2006 8D - Drops / 2006 8G - 2006 SI S8B - 2006 S8C - Eagle / 2006 S8D - Drops / 2006 S8E - 2006 SI S - 2000 / 3000 Series SAA - E300TX Euro1 Eagle SAC - E335TX Euro1 Eagle SAF - E375TX Euro1 Eagle SAG - E400TX Euro1 Eagle SAJ - E340TX Euro2 SAK - E380TX Euro2 SAL - E410TX Euro2 SGA - TAG1A Elektropak / Gen Sets SGB - TAG2 Elektropak / Gen Sets SGC - TAG2A Elektropak / Gen Sets SGD - TAG3A Elektropak / Gen Sets SGE - TAG4 Elektropak / Gen Sets SGF - TG Elektropak / Gen Sets SGG - TG1A Elektropak / Gen Sets SGH - TG2A Elektropak / Gen Sets SGJ - TTAG Elektropak / Gen Sets SGK - TWG2 Elektropak / Gen Sets SGM - TAG5 Elektropak / Gen Sets SGN - TAG2B Elektropak / Gen Sets SGP - TAG1B Elektropak / Gen Sets SHA - 2006 TWH SIA - SI Combined Heat / Power SIB - SI Combined Heat / Power SIC - TSI Combined Heat / Power SID - TSI Combined Heat / Power SMA - M600TI Condor Marine SMB - M700TI Condor Marine SMC - M800TI Condor Marine SMO - M600/700/800 Duffield Opt Kit SPA - Industrial 17T SPB - Industrial 12T1 SPC - Industrial 12T2 SPD - Industrial 12TA SPM - Industrial 12TW SPN - Industrial 26TW1 SXA - Prototype SXD - Prototype SXG – Prototype SXI - Prototype SXM - Prototype SXP - Prototype 2300 / 2800 Series 2300 - 6 Cylinder FGA - 14L TAG1 Generating Sets FGB - 14L TAG2 Generating Sets FGD - 14L TAG3 Generating Sets 2800 - 6 Cylinder HGA - 16L TAG1 Generating Sets HGB - 16L TAG2 Generating Sets JGA - 18L TAG1 Generating Sets JGB - 18L TAG2 Generating Sets JGD 4000 Series D - 4000 Series DGA - TAG1 Generating Sets DGB - TAG2 Generating Sets DGD - TAG3 Generating Sets DGE - TAG4 Generating Sets DGF - TG Generating Sets DGK - TWG2 Generating Sets DGL - TAG Generating Sets DGM - TWG Generating Sets DGN - TWG3 Generating Sets DGP - TEG Generating Sets DGR - TEG2 Generating Sets DGS - TEG3 Generating Sets DGV - TWG2C Generating Sets DIE - TESI Combined Heat / Power DIF - TESI Gas Unit DIG - 4016E61TRS DME - Seaking – Marine Transmissions and Brakes 1,Meritor WABCO toolbox D and E Versions ,HABS, hpb, ESC, RSC, ECAS 2,Bendix ACom Diagnostics EC-17T, Generation 4 and 5, EC-30T, EC-60T (standard, premium and advanced),A-18T,MC-30T and the trailer antilock braking TABS-6 unit 3, Meritor ZF 4,Eaton Service Ranger Vorad VS-400 Collision Warning System Generation 2 Auto shift and Ultra shift Transmissions Generation 3 Auto shift and Ultra shift Transmissions Ultra Shift PLUS Transmissions Lightning Transmissions Hybrid Drivetrain Systems 5, Allison DOC Allison1000, 2000, 3000, 4000, Cec2-5610, 6610, 8610, 9610 CEC-MTB600, CLBT-V, HT700, B700 CEC-5, CEC-6, CEC-8, CEC9000 XTruck USB Link Cables and Adapters http://www.esldomino.com/userfiles/n...cable-list.jpg Package List: XTruck USB-Link module PN: 125032 6PIN deutsch and 9pin deustch ”Y” PN: 405048 16PIN J1962 (OBD2) PN: 448013 16PIN J1962 (Heavy Duty)-j1708 PN: 444009 USB cable PN: 403098 http://www.esldomino.com/userfiles/n...ftware-g12.jpg http://www.esldomino.com/images/Contact_Us.gif |
