How to Reset Windows Vista Password
Vista password reset help? Ok, here's my problem; I have a home PC running Vista home premium 32 bit op. I have two accounts: one limited account with a password to just log into and the original admin account that has no log in password. The mom set this account as the one with admin privileges but forgot the administrator password, I can't reset it with cmd.exe, I've tried several commands looking for a way to clear the password without wiping my drives. After consulting my IT friends, I get a quick response. There is a Windows Vista boot disk that will allow me to reset password on Windows Vista. It is Linux based and uses a very easy menu system. Any way, I am not a computer expert; I can't listen to this friend for further info. I need a more easy way! Then I wonder if isn't there a program without a boot disk? it would be much easier for me but thanks anyways! What a pity things is that another friends answered my question: Not really, most Windows password recovery requires a boot disk, unless the main admin account is not password protected. Try accessing it by pressing f8 during boot and entering safe mode. Once asks for login, press ctrl-alt-del, and type in administrator. This might work. While, I have only one administrator account - the default admin! I search my password question words via Google, what's surprised me is that here is one site that might help me. It is named Windows Password Recovery Tool that will work for any Windows OS, also include Windows Vista. This tool is a well-known professional third party application designed for particularly Windows Password Recovery. To operate such a tool is very easy, even though I am a newbie, I can fully understand and follow the below steps to finish the task. Now, please follow me: Step 1: Google search Windows Password Recovery Tool, get results from suggestion; Step 2: Download needed Windows Password Recovery Tool Professional and install it on an accessible pc; Step 3: Burn a password reset disk with a blank USB Flash drive. Step 4: Insert the burned reset disk into password lost computer, and set the computer to boot from USB drive to reset password Windows Vista. Things now become easy! From this day, I think I will never take such experience make me mad! Now, I get new password for my pc login. What's more, I disable the Windows Vista default Administrator and create a back up admin account! For security purpose, disabling the built-in Administrator account on our personal computer is very necessary since the default Administrator can do anything to your computer, like delete crucial files, delete accounts and reset other user password etc. So avoid this by making another account which is not names as Administrator but with administrative privileges. Also, I prepare another way to help me reset password Windows Vista login password - create a password reset disk for my admin account! Dear reader, if you are a Vista OS pc owner, you can also take the following steps to help you save much time once you lost password: Step1. Insert a prepared USB flash drive into your computer. Step2. Type "reset" in the Windows search box and select "Create a password reset disk". Step3. When the "Forgotten Password Wizard" appears, click "Next". Step4. Select your USB flash drive and click "Next". Step5. When the wizards finish creating the reset disk, please click "Next" and then "Finish". Thanks for the help, I was just looking how to reset Windows Vista password through password reset disk though, but the above tips helped. |
| All times are GMT -5. The time now is 04:29 AM. |
