How to remove Windows 7 password?
Old Sep 6, 2012 | 09:50 PM
Lohan's Avatar
Default How to remove Windows 7 password?
I forgot my administrator password? How to remove Windows 7 password?
So i forgot my password but can log in as guest...and i didn't to the recovery disk or anything... so what’s the best way (free) to remove the password? Can I use USB flash drive to do it? Help please and thanks!! : )
I have used the following methods from my workmates:
First: Check if the caps lock has been turned on - if it hasn't - type the password in one key at a time with one finger, slowly - I've found out that I had my fingers off one key on one hand, which made me enter the wrong password by whatever keys were being typed by that hand.
Second: If the first one doesn't work - try using F8 to get into Safe Mode to see if you can remove the password.
Third: Remove Windows 7 password with Windows Password Recovery Tool 3.0. It is a easy-to-use Windows 7 password remover tool that helps you create a disk within minutes. Just follow the steps below:
1. Login a pc that you can download something. Download Windows Password Recovery Tool Professional, install it with several clicks and then run it.
2. Burn a Windows 7 password reset disk with a blank CD/DVD or USB Flash Drive. A USB Flash Drive will be better if the locked Win 7 pc with the driver.
3. Connect the burned Win 7 password reset disk with the locked Win 7 computer, Press DELETE, F1, F2, F10, F12 or Alt+S (choose one or combined key that screen may display a sentence while computer starts), then set bios to boot pc from USB Flash Drive, restart pc and there will load software program.
4. Choose the user account that you need reset the unknown logon password, click "reset" button to begin password reset.
5. A message box will pop up, just click "Yes", then the login password will be reset a new one.
6. Shift out this Windows 7 password reset disk, restart PC with logon password problem. Now you will successfully logon Windows 7 without password after remove windows 7 administrator password.
BTW, I get the related video on how to remove password, please view from:
Also, share the forth solution to all Windows 7 users, it will help them make good preparation before need remove Windows 7 password:
Forth: Create a password reset disk before we remove Windows 7 administrator password:
1. Connect a blank USB flash drive with your unlocked computer.
2. Click your user account icon on the Start menu and select "Create a password reset disk" when User Accounts dialog box displays.
3. Input: password reset disk the three words in the Search box. When the "Forgotten Password Wizard" appears, click "Next".
4. Select your USB flash drive and click "Next" to enter current password.
5. When the wizards finish creating Windows 7 password reset disk, the file named userkey.psw will be in your USB.
Old Sep 7, 2012 | 06:19 AM
preetisoft2's Avatar
Default Hello
Thanks for this information. Its really very useful for me.
Old Sep 8, 2012 | 08:33 AM
marion123's Avatar
Member
Thanks for letting us know on windows 7 password. You method noted down.
Lohan
Jan 10, 2013 12:23 AM
