How to Convert VOB to MOV on Mac at ease
Why we convert VOB to MOV? VOB is short for Video Object which is the container format in media. Files in VOB format have .vob filename extension and are typically stored in the VIDEO_TS folder. Generally, VOB files are in large size, one file may be about 1GB. What's more, VOB is supported by few media players and portable devices. MOV is the video format of Quicktime developed by Apple Computer. So, MOV is highly compatitable with apple applications and devices. Therefore, if you want to play a VOB file in Quicktime or if you want to edit the video in iMovie, you need to convert VOB to MOV. The Video Converter for Mac is a nice program which will help you make the conversion at ease. The fast conversion speed and lossless output quality will make you feel satisfied. How to Convert VOB to MOV on Mac? In order to make users learn more about the program, we provide a detailed tutorial as below. You can download the program and try to make the conversion as following steps.. Note: This tutorial is for Mac users, if your are a Window user, please go to the Video Converter for Windows guide for more information. buy video converter mac download video converter mac Step1. Import files to the program Start Video Converter for Mac and directly drag VOB files to the program. This is a very convenient way. You can also click "File" item on the tool bar to import files. Batch conversion is also available. mkv to mpeg mac video converter main interface Step 2. Select MOV as the output format Please click “Output Setting” icon can select MOV as your output format in the "Format" list. If you want to convert VOB to other formats, you have a wide option for the output profile as shown in below picture. mac video converter vob to mov output format interface Step 3. Customize output setting Before VOB to MOV conversion, you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the output setting menu for better enjoyment. mkv to mpeg mac mac video converter output setting options interface Step 4. Start VOB to MOV conversion on Mac Please click "Convert" button at the bottom right, conversion will begin at fast speed and superb quality. You can also stop and delete the conversion during the process. mkv to mpeg mac mac video converter conversion interface Tips on VOB to MOV Converter for Mac: 1. If you want to make the output video more special and impressive, you can click “Edit” item on the tool bar or just click the edit icon to make edition through trimming, cropping, adding subtitle and watermark. 2. This program supports to convert videos and audios for playback on various portable devices like iPhone, iPad, iPod, iPod Touch, Apple TV, PSP and so on. 3. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep", "Shut down my computer" and "Do nothing" three mode options. |
I think you explained it very well and it contains very good information.
| All times are GMT -5. The time now is 12:23 AM. |
