How to Convert M4V to MOV on Mac
Old Aug 28, 2012 | 12:17 AM
windyjhzt's Avatar
Default How to Convert M4V to MOV on Mac
m4v iconmov iconM4V file format is a video file format developed by Apple and is very close to the MP4 format. Because the copyright of M4V files is protected by using Apple's FairPlay DRM copyright protection, you may can not play M4V files in Quicktime, iTunes, iPhone, iPad and so on. At this time, you may would like to convert M4V to MOVwhich is high compatitable with apple devices.
Here we recommend a professional M4V to MOV converter for Mac which supports to convert between a variety of common video and audio formats on Mac. You will learn more about this program from the following tutorial and you can also download the trial version to experience the powerful functions of the Video Converter for Mac.
What's the guide about M4V to MOV conversion on Mac?
Note: Below tutorial is for Mac users. If you are a windows user, please go to the Video Converter for Windows guide for more information.
Step1. Add files to the M4V to MOV Converter
Start Video Converter for Mac. You can directly drag M4V files to the program or click “File” icon on the tool bar to import files.
For users' convenience, batch conversion is also available.
m4v to mp4 mac video converter main interface
Step 2. Select MOV as the output format
Click “Output Setting” icon and open the "Format" list, here you should choose MOV in the "Common Video" menu as your output format.
m4v to mp4 mac output interface
Step 3. Adjust video parameters
Before M4V to MOV conversion, if you want to set the video and audio parameters, please click "Options" item on the "Output Setting" menu. You can adjust the codec, resolution, frame rate and bit rate to make the output video perfect.
m4v to mp4 mac video converter output setting
Step 4. Begin M4V to MOV conversion on Mac
Press "Convert" button, all the tasks will begin with high efficiency. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep", "Shut down my computer" and "Do nothing" three mode options.
m4v to mp4 mac video converter conversion interface
Tips on M4V to MOV Converter for Mac:
1. This program has video editing features. You can click “Edit” item in the tool bar or just click the edit icon, then you can make the edition by applying special features to the output video through trimming, cropping,adding subtitle and watermark.
2. Video previewing is allowed before M4V to MOV conversion.
3. You can make a screenshot when previewing the origial videos.
windyjhzt
Mar 3, 2021 02:24 PM
steven1joen
Jun 25, 2013 10:12 AM
