Vag Com 11.10 Vcds 11.10 Vag 11.10 Vcds V11.10 Vag Com Vag
VAG COM 11.10 is the first aftermarket VAG-Tool that: 1, It is fully compatible with all VW, Audi, Seat and Skoda models through the current model year, including models using a direct CAN connection for diagnostics. 2, It has a database of more than 14000 fault-codes and measuring-block texts. 3, It can use the new 7-Digit PIN/SKC codes to match new keys in all immobilizer equipped VW/Audi/Seat/Skoda models. 4, It allows you to view, log, and graph 3 groups of Measuring Blocks at once 5, It can access all control modules which require proprietary VAG modes running the KWP-2000 protocols (2001+ Teves Mk.60 ABS, numerous 2002+ modules), KWP6000 (CAN) and/or KWP7000 (UDS). 6, It can display critical timing information on TDI engines in graphic form |
| All times are GMT -5. The time now is 08:56 AM. |
