wheels for sc430
needing to get wheels for the sc the factory wheel offset are 45mm
saw some wheels but the offset is 42mm what will I have to do to make these work if I can?:confused: |
If they are 18" wheels I would use the factory 45mm offset only. I have had problems in the past with suspensions bottoming out with non-standard offsets.
If you want to go to larger diameters then you will need to search for the proper offset - maybe on tire rack? |
| All times are GMT -5. The time now is 05:31 AM. |
