wheels for sc430
Old 01-30-2017, 04:56 PM
kengonz's Avatar
Default wheels for sc430
needing to get wheels for the sc the factory wheel offset are 45mm
saw some wheels but the offset is 42mm what will I have to do to make these work if I can?
Old 04-14-2019, 01:49 PM
ivanj's Avatar
If they are 18" wheels I would use the factory 45mm offset only. I have had problems in the past with suspensions bottoming out with non-standard offsets.
If you want to go to larger diameters then you will need to search for the proper offset - maybe on tire rack?
kevin32
07-29-2021 11:24 AM
OEWHeelsLLC
07-29-2021 11:09 AM
rstanis
02-05-2018 03:46 PM
CodeNameU
09-06-2017 05:24 PM
Kip Olson
02-03-2010 11:20 PM
Quick Reply: wheels for sc430
