the trunk won't pop
Yes my car has problems.
But last month I bought a new battery, and after hookng it up... my trunk no longer pops. I can't even turn the key in it. Do you know whats wrong? |
RE: the trunk won't pop
This may be a very naive answer, but I've had both the problems you're experiencing, although, not at the same time. My trunk wouldn't pop because my knee accidentally hit the button on the right side below the steering wheel, which you can switch on and off, a valet protection feature. And also, if you happen to be using the valet key, it won't work in the trunk, you have to use the above described button to open the trunk. |
| All times are GMT -5. The time now is 12:19 AM. |
