-   -   START UP AND DIED INSTANTLY (https://lexusforum.com/forum/lexus-sc-13/start-up-died-instantly-149/)
sc300 Mar 8, 2006 04:04 PM
IS THERE ANY ONE CAN TELL WHAT IS HAPPENING TO MY CAR , I STARTED UP AND THE CAR STARTED TO DIE, YOU CAN'T GIVE IT ANY GAS OR IT AUTOMATIC DIED.
stonewis Dec 1, 2006 04:48 PM
RE: START UP AND DIED INSTANTLY
I had the same problem. Mine turned out to be a fuel pump ecu. It's located on the back bulkhead behind the seat back. You can find them for about $50 used.
Patrick Dec 6, 2006 03:38 PM
hopefully he sees this..its been a while.
al3hoops Sep 19, 2009 11:52 AM
hope you check this today..where is the fuel pump ecu located on you SC400
jagbomb Oct 9, 2009 09:35 PM
hey im selling my 1997 white sc300. anyone interested get at me jagbomb90@yahoo.com or check my ad on craigslist, vehix.com
lovely09 Oct 18, 2009 01:33 AM
What is needed for an engine to start?
1. The engine must be turned over by the starter motor with enough speed to catch. For this to happen,the battery must have enough charge,the starter motor and the starter circuit should be OK.
2. Fuel mixed with air in the correct proportion must be supplied to the enigne cylinders;
3. Spark - there must be a strong spark at the proper moment to fire the air/fuel mixture.
4. Proper timing - the engine valves should open and close in appropriate time.
5. Compression - normal compression in the cylinders is 120 - 170 psi.The engine won't start if the compression is lower than 70 - 80 psi.
If the engine won't start, one of these things is probably missing.
BigRed Sep 23, 2012 01:27 AM
I have the same problem with my LS400 please let me know what you find out
