-   -   1uzfe engine and trans w/85k for sale (https://lexusforum.com/forum/lexus-sc-13/1uzfe-engine-trans-w-85k-sale-24565/)
pwonder May 5, 2009 01:47 PM
Northern NJ, Both of these came out of my 93 Lexus Sc400 that was in immaculate shape with between 82k-85k miles. Car was hit in rear. After the hit i had the car stored in my garage for a number of years before striping it. I bought another sc400 that had a bad interior and used the interior from this car since it was immaculate. I kept the engine and trans for a while thinking that if i ever had motor or tranny issues i would just swap them, but these engines and transmissions are so solid and hardley ever die i never needed to use them.
engine is good for SC400 years 92, 93 , 94, 95 , 96 I also know that the LS400 has the same engine, just not sure of the exact years( please do your own research, i dont want to steer anyone the wrong way)
I know a mechanic that will do the swap for $450
transmission is good for SC400 years 92, 93, 94, and i think 95 aslo nut you have to swap a piece that is on the end of the trans that attaches to the driveshaft. Not sure about the LS400...??? Might be good for the Ls also because they have the same engines....im not sure.
Same mechanic will swap the trans for $400
asking $400 for motor and $400 for the trans
call 201 315 9159 leave a message if no answer
doingit68 May 17, 2009 05:22 PM
My question is; I have a 92 SC400 and my passenger side window will not go down without playing with the drive side wires that goes into the driver side dr. The only way I could at one time let the window up, were only by the passenger window buttons. Now neither the driver nor passenger window button will let the window up. Is it the window motor or some other problem? I can hear a buzzing sound after I press the passenger window button. What should I do? Thanks for any advice you may render. Do you have either a passenger window motor or button housing?
ema Jul 7, 2009 02:48 AM
Perhaps it is not the motor per se. You might had some loose wirings with your passenger windows and had caused another at your driver windows as you played with it. Try checking up for loose wirings. If not, try checking out the window switch.
______________________________
pretty strong lexus parts on the track
