1993 Lexus SC 300 CD changer
Old May 14, 2006 | 11:14 AM
spinmouse's Avatar
Default 1993 Lexus SC 300 CD changer
I need to replace the CD changer, which is mounted in the trunk, on my 1993 SC300. Dumb question: how does the old one come out?
Old Mar 15, 2007 | 02:05 AM
mrhappi's Avatar
Default RE: 1993 Lexus SC 300 CD changer
Just to let you know. Remove the cover on the right which is held on by mostly clips. Once you remove that you can see that there are two bolts on top holding the changer in place and then underneath the changer there are also a couple more bolts. Once you remove the metal brackets holding the changer in place then just replace the changer then put everything back to the way it was. Mind you I haven't taken out my changer for quite sometime now so some details may be a bit fuzzy, but this should help you out.
rcpeters
Jul 29, 2021 11:42 AM
derby2*
Jul 29, 2021 11:37 AM
gage
Jul 21, 2007 01:39 PM
desidude718
Nov 13, 2006 05:02 AM
tide1
May 4, 2006 11:41 PM
