Monitor Mac System Status with Free Magican Monito
Monitor Mac System Status with Free Magican MonitorFree Magican Monitor is a redefined app which is different from other monitoring programs, it’s an float window inspect your network speed first, and once mouse touched, memory, disk,monitor mac, CPU, sensor and battery information will be popped-up. This window is user-customized; you can freely remove or add each item at will. For the features part, Magican Monitor is also different from other monitoring programs. To help you get more clearly information about CPU usage, memory usage and disk space, both data and graph displays are designed to help you visually analyze data. The highlight of battery is that it can alert you when battery is too lower, this can avoid of sudden shutting down of your Mac. This free app is fit for the Mac 10.6 or later.
