Error codes P0100, P0110 & P0171 point to any one thing??
Old Jun 12, 2008 | 10:46 PM
Pk2's Avatar
Pk2
Default Error codes P0100, P0110 & P0171 point to any one thing??
I have the above trouble codes My OBC reader identifies these as, I wondering if the indicate 3 problems or all point to one. Also, what that problem or problems might be:
P0071: System too lean bank 1
P0100: Mass or volume air flow circulation malfunction
P0110: Intake air temp (AT) circuit malfunction
Recently the smog test center had given me P0101 (I think), I cleaned the MAF (which did not appear particularly dirty or damaged). The CEL came back on and I got the code above codes.
(Don,'t know weather this has anything to do with anything but according to my OBCII software there are some zero voltages of “0v.” on 2 of 3 “sensor short term fuel)
Regards, PK
Hello,
Old Jul 11, 2008 | 08:48 PM
lexustek's Avatar
Default RE: Error codes P0100, P0110 & P0171 point to any one thing??
Replace MAF clear codes and all will be well.
Old Sep 11, 2008 | 06:27 PM
khooper's Avatar
These are the meeaning of the following engine codes.
P0100 Mass or Volume Air Flow Circuit Malfunction
P0110 Intake Air Temperature Circuit Malfunction
P0171 System Too Lean
______________________________________
Check out the AUTO PART
Old Sep 12, 2008 | 12:40 AM
Pk2's Avatar
Pk2
Thanks,
It was the maf.
Regards, PK
lvtobike
Jul 29, 2021 11:04 AM
lbb
Nov 29, 2011 01:03 PM
redcarwire
Apr 21, 2010 03:51 AM
cici
Dec 26, 2009 04:34 AM
rockerfella174
Dec 12, 2008 02:55 AM
