-   -   Door Panel Removal? (https://lexusforum.com/forum/lexus-rx-16/door-panel-removal-469/)
nghiaho58 May 5, 2007 08:13 PM
Door Panel Removal?
My Power Windows does not move up or down, I believe there is something wrong with the wriring or the motor inside the door. I am having trouble removing the door panel, does anyone have a Door Panel Diagram to remove it? Thanks!
TWQ83 May 8, 2007 11:08 AM
RE: Door Panel Removal?
What Model?????
Tacoma25 Mar 7, 2008 10:47 PM
On the first gen RX's you need to remove a screw hidden behind the panel in the center of the release handle, and there is another under the window switch trim. On the 2004 and up, there is a screw behind the panel in the center of the release handle, I think there is one under the switch panel trim, and another down under the felt in the door handle, the rest are clips. Also pull th trim on the A-pillar.
