OBD Code
Old 08-19-2007, 08:35 AM
lvtobike's Avatar
Default OBD Code
Help!
I'm ready to leave on vacation and I've had two warning come on at the same time!--- check engine and VSC.
I have a 2001 RX300 AWD with 62,000 miles.
The OBD code # is 1135. This seems to indicate A/F Hrt Cir.
Bank 1 Sensor 1.
I ran STP full system fuel cleaner thru the engine for a week. I reset the computer (disconnected the plus battery terminal) for about three mintues, but the indicators came back on after I started the car, in about 1 minute.
Is this one or two problems? What is bank 1 sensor 1?
As I stand at the front of the engine, there is a sensor in the manifold at the front of the engine.
I don't want to buy a Ox. sensor if I don't need it. They are expensive!
Is the vehicle safe to drive? It runs great--no miss and no rough idle! PLEASE HELP ME!!
Old 09-15-2007, 01:31 AM
Default RE: OBD Code
I think it will cause poor fuel economy. If there are no other choice, you have buy Lexus oxygen sensor for your car performance protection. If your problem is high price, you can rely on ebays. I know there's a lot of cheap one out there. Goodluck!
Old 10-21-2008, 12:39 AM
you will be ok cause it is the heater circuit inside the o2 sensor that is bad not the o2 itself. thats what is throwing that code. the o2 just won't heat up and produce a usable signal to the computer as quick. one the engine has warmed up for a little bit the o2 should be reading just fine. there is an updated part to take care of that concern. i would replace it but it would be OK FOR THE TIME BEING. good luck!
Old 12-11-2008, 10:05 PM
I wonderd what "Hrt" was
  #5
Old 12-14-2008, 04:47 PM
patrick-xie
09-03-2012 04:28 AM
sunnyou
11-17-2011 01:35 AM
sunnyou
11-15-2011 03:59 AM
bevans
06-14-2006 02:41 AM
Quick Reply: OBD Code
