05 RX330 struts. Warning lights!!!
OK, my 05 RX330 has 290K miles. I changed the rear struts. Now the ABS & brake light is on. The low tire light is flashing constantly!! When changing the struts I didn't disconnect any brake lines other than the brackets that attach to the struts. Now, the car is setting 3"-4" higher in the rear due to the new struts/springs, which the instructions with the struts said would happen. I just don't know why these lights are on!! I disconnected the battery overnight, hoping the lights would reset, but that didn't work either. They don't show up on the code reader either!!
Any suggestions?? |
| All times are GMT -5. The time now is 06:09 AM. |
