Oil Change Please Help
Hello,
I recently purchase a new LS460 and love it. My first oil change was done free of charge at the dealer. At that time, I bought a filter so I could do the next one myself. I found where the flap is and the filter. I tried putting a socket in the hole and the metal "plug" cam out. It looked as if I needed a filter wrench for the next part. I bought the right size and put it on. It is on so tight that I bent the filter wrench. Unbelievable. Yes... I took the little clip off. Please help, I am stuck!!! Thanks in advance... BTW, I saw a post on this once before with pictures but of course can not find it! Thanks in advance for your help. Nate |
RE: Oil Change Please Help
isn't the second oil and filter complinetary as well? I would call the nearest Lexus Dealership and find out. It was my understanding that the first 2 oil and filter are done complimentary.
What do you mean "stuck"? when you put the filter on, you need to coat the gasket on it w/ oil. Also, the filter does not need to put on tight, only hand tight. Too tight you will damage the threads
| All times are GMT -5. The time now is 04:06 AM. |
