New battery in key remote
Old Jan 15, 2008 | 07:02 AM
lojkom's Avatar
Default New battery in key remote
I have a 1994 LS 400 that did not have an owners manual when I purchased it. I have recently replaced the battery in the key remote but the remote still won't work. What do I need to do?
Old Aug 20, 2008 | 10:11 PM
applevalleyjoe's Avatar
Default RE: New battery in key remote
I had the same problem with a 98 remote so I went to Lexus and bought one of their remote batteries and had them install it...no more problems.
Old Aug 21, 2008 | 09:59 PM
khooper's Avatar
Your Security problem is most likely caused by a faulty ignition switch and passlock sensor.
The PCM and BCM will set DTC's to aid with the diagnosis of your problem.
_________________________
A Real Auto Dude Drives Safely
Old Aug 22, 2008 | 04:18 AM
rockerfella174's Avatar
i agree with khooper,
IT could be youre immoblizer.. where after you replace youre batter remote it couldnt reconized.
suggest to go to lexus dealer to check & diagnosis the faulty...
Old Sep 23, 2008 | 03:53 PM
  #5
outbid81's Avatar
Don't listen to Khopper and rockerfella, they don't know what they are talking about. A 94 LS does not have an immobliser system and there are hardly ever failures in the ignition circuit. No DTCs will be set because this OBD I system has only the very basic codes. Your most likely culprit is the key itself which happens fequently on this model. There is a test the dealer can do to check the signal. If it is, in fact, the key you would have to order a kit which includes two new keys and a ROM chip for the wireless ECU. Unfortunately, a new key cannot be programmed to this sstem. Sometimes you just have to bite the bullet and take it in.
ram
Jul 13, 2021 09:09 AM
sunnyou
Nov 17, 2011 03:13 AM
ram
Dec 15, 2009 09:01 PM
naveed
Apr 5, 2009 06:08 PM
SpdWhite
Jan 16, 2009 07:53 AM
