LS430 Headlight Ballast Change
Passenger side low beam light is out, changed hid bulb but no luck. I removed one screw from the ballast cover but can't reach the other (it was full of water). Do you have to remove entire headlight assembly just to change the ballast or is there an easier way?
| All times are GMT -5. The time now is 08:15 AM. |
