-   -   headlight problem (https://lexusforum.com/forum/lexus-ls-9/headlight-problem-27020/)
kars365 Apr 15, 2010 06:58 PM
headlight problem
just purchased a 06 ls430. Problem is left low beam does not work. changed bulb with right side so both bulbs are good, fuse under the hood is also good. is there any relays for the headlights or any other suggestions. thanks for your help. no power to l/s headlight. thanks artie
joshua baldwin Apr 27, 2010 04:38 AM
something could be shorting out causing it not to work or there could be problems with your integration relay
