1990 LS400 - intermittent stalling
Old Dec 6, 2012 | 07:37 PM
400's Avatar
400
Default 1990 LS400 - intermittent stalling
Have intermittent problem - car is warm - generally driven 20-30 minutes - generally warm/hot weather - will begin to stall - erratic stall/surge - unresponsive to throttle for few seconds - shutting off and cooling down will allow return to normal operations. Lexus dealer replaced O2 sensors but problem returns - intermittently. Someone suggested catlytic converter could be instigator: heat up causes collapse/restriction in cat and exhaust becomes restricted. When problem occurs the car feels starved for fuel/air - choking. Anyone ever had similar?
Old Dec 10, 2012 | 02:34 AM
kingsure's Avatar
now its demanding for the password to extract files. there was no file with that
cheap nike shoes from china
Nike LeBron James 6
Nike LeBron James 8.5
Old Dec 18, 2012 | 07:43 AM
Barrett077's Avatar
I think you need to check the coolant levels of your car.if they are ok then check the engine oil because its also can be a reason for that problem that may be the oil is become junk and it warm your engine body.or may be its due to the hot weather. If its overheated more then the normal routine then I suggest you to install a exhaust fan in the hood of your drive.
Old Jan 11, 2013 | 12:36 AM
TamikoPrince's Avatar
AlexAgyagos
Jan 12, 2010 04:26 PM
blackls400
Feb 28, 2008 08:06 PM
ruskibusiness
Mar 7, 2007 04:02 PM
ruskibusiness
Mar 7, 2007 04:00 PM
walkdb
Jul 31, 2006 02:39 AM
