DIY Article: How to replace the camshaft position sensor on a GX470
Hello again Lexus faithful!
Today's instalment of my ongoing DIY article series illustrates how to change the camshaft position sensor on a LX470. Ready to turn the wrench? Then let's go! :cool: **Reference Material** Lexus GX470 Timing Gear and Cover diagram 1) Drain engine coolant. 2) Remove v–bank cover sub–assembly. 3) Remove fan & generator v belt. 4) Remove oil cooler pipe. 5) Remove timing belt cover sub–assembly no. 3 LH. 6) Remove camshaft position sensor. 7) Disconnect the camshaft position sensor connector. 8) Remove the bolt, stud bolt and camshaft position sensor. To Install: 1) Install camshaft position sensor. 2) Install the camshaft position sensor with the bolt and stud bolt. 3) Torque: 66 inch lbs. (7.5 Nm). 4) Reconnect the camshaft position sensor connector. 5) Install timing belt cover sub–assembly no. 3 LH. 6) Install oil cooler pipe. 7) Install fan & generator v belt. 8) Add engine coolant. 9) Check for engine coolant leaks. 10) Install v–bank cover sub–assembly. |
| All times are GMT -5. The time now is 09:57 AM. |
