DIY Article: How to replace the camshaft position sensor on a GX470
Hello again Lexus faithful!
Today's instalment of my ongoing DIY article series illustrates how to change the camshaft position sensor on a LX470. Ready to turn the wrench? Then let's go!
**Reference Material**
Lexus GX470 Timing Gear and Cover diagram
1) Drain engine coolant.
2) Remove v–bank cover sub–assembly.
3) Remove fan & generator v belt.
4) Remove oil cooler pipe.
5) Remove timing belt cover sub–assembly no. 3 LH.
6) Remove camshaft position sensor.
7) Disconnect the camshaft position sensor connector.
8) Remove the bolt, stud bolt and camshaft position sensor.
To Install:
1) Install camshaft position sensor.
2) Install the camshaft position sensor with the bolt and stud bolt.
3) Torque: 66 inch lbs. (7.5 Nm).
4) Reconnect the camshaft position sensor connector.
5) Install timing belt cover sub–assembly no. 3 LH.
6) Install oil cooler pipe.
7) Install fan & generator v belt.
8) Add engine coolant.
9) Check for engine coolant leaks.
10) Install v–bank cover sub–assembly.
To Install:
