2005 GX470 - How long will it last
I had my 05 GX470 since 2005 when it was new. Love that car. For the past 12+ years, I changed oil and filter regularly every 5000-8000 miles. Engine stills run fine but I got the impression that it is not as punchy as when it was a few years back. Timing belt and water pump were changed at 90K miles. Experienced leak at the edge of the radiator at 120K miles (apparently common) and radiator was replaced. All fluids (power steering, front differential, rear differential, transfer case) were replaced at 80K miles and at 160K miles. Front CVs and rear shocks were replaced at 130K miles.
The vehicle now has 175K miles and probably ready for another timing belt and water pump change. I am debating if I should keep the vehicle much longer. If so, how many extra miles will I get out the vehicle if I continue to do regular oil/filter change? |
Keep it and see how long it will last. Knowing the history of a vehicle is like the peace of mind. Keep up on the maintenance and I would imagine you can more than double the miles you have now. Consider replacement of emission sensors, that could be what is taking away the zip in your trusty ride. Those sensors are ready to be replaced at the 10-year mark I believe.
https://cararac.com/blog/2004-lexus-...r-gx-last.html |
Bullet proof
Originally Posted by gordonla9
(Post 51639)
