Lost Key - Need New Key - Help!
I have a 2000 GS300, and lost the master key. I now have ONLY a spare key. The dealer says that they cannot make another key without the master key, and they'll have to replace the computer in the car - very expensive. Is there another way to make a key?
Thanks a lot, Ram |
The master key is linked to the computer I dont believe there is another way. making a new master key even with the original is a process in itself
Thanks Donny for your reply. This is just too bad, that a lost key will end up costing about $2,000! I wonder if one can find a computer and keys from a junk yard?
I have the same problem... how much is to replace the computer?
Lost Key
Although not every dealer will tell you this, I found out from one dealer that Lexus provides, for free, the computer, a $1500 device. But, they require you to buy two master keys, in addition to installation labor charges, totaling to about $900. You must shop around. You can also call Lexus and ask the they provide a discount, as this was an "admitted" design flaw through 2003, and they changed the design in 2004, making it like other cars. Hope this helps.
Lost Lexus key = no problem
Originally Posted by ram
(Post 28279)
I used to work for an auction. We had an automotive locksmith come out to reprogram the ECU's that the dealer says cannot be reprogrammed - and for a lot less $ than new ECU. He never encountereed a Lexus that he could not do. There are also sellers on ebay that do it by mail, but I would check feedback first. |
Then what a locksmith has got you from the auction.
You can easily get it programmed by any auto locksmith near, there is no need to worry about it.
| All times are GMT -5. The time now is 06:09 AM. |
