engine noise
has anyone had any issues with excessive engine noise in an 06 gs300? my previous 99 gs300 and 91 ls were so quiet i had to look at the tach to see if it was running. i can hear my 06 in the cabin with the windows up and seems to be getting louder, car has 9000 miles and will be going in for service soon. i would like to know if it is a common issue before i address it with the dealer.
The '06 GS uses a different engine with a dual fuel injection system. The high pressure system operates at pressures way in excess of 1000 psi and makes a little more ticking noise than previous models, this is normal.
I got an 06 GS 300 as well. lexustek is right. Mine has a slight sewing machine sound going on when you stand outside w/ engine at idle. But this is normal due to the high velocity fuel system. I tried Sunoco Ultra 94 fuel and same thing - just in case it was octane related. Car is awesome otherwise. You can't hear the tick from inside the car cockpit though. You'll get use to it.
rkerr1234
Jul 29, 2021 11:33 AM
