Replacing Blower Resistor Transmitter
Hello Everyone,
I have a 96 lexus es300 recently the blower only operates on high. I found out that the Blower Resistor Transmitter controls the lower speeds. I want to replace it but I don't know where it is located can someone please tell me where this part is located I have looked in the area where the blower motor is but I don't see it. Please need help quick!!!! Thanks, RICCO |
RE: Replacing Blower Resistor Transmitter
if youre going to get into that sort of thing, i would try to get a repair manual. in most cars that i have dealt with, the blower resistor is under the dash, somewhere..[:@]
Found Blower Resistor Transmitter
Hey everyone I found where the blower resistor transmitter is located. I had remove the radio
because the dealer told me it was located behind it but not so. I followed the wires from the ac/heater control to the base of the unit on the driver side and located the resistor to the right of the gas pedal at the base of the ac unit. know its on to the salvage yard. Hope this helps someone in the future. Ricco |
RE: Found Blower Resistor Transmitter
Mine is only working on low speed. did you find and change the resistor transmitter? Did it fix problem?
Thanks, Bob |
