leaking when raining
Old Jul 22, 2008 | 01:54 PM
Commodore's Avatar
Default leaking when raining
I have a 2005 ES 330 with just over 50,000 miles. Recently, it started leaking rain water whenever it rains, even sprinkles. The rain water collects on the passenger side floor and right rear seat floor only, no where else. I can extract quarts of water when it rains hard. There is absilutely no evidence of rain on any other part of the interior, only the flat floor as described. I have soaked up quarts of water with a shamwow and a wet vac but it keeps copming back every time it rains. Maddening. Has anyone had that trouble?
Old Sep 23, 2008 | 04:17 PM
outbid81's Avatar
Default RE: leaking when raining
Check the drain tube for the A/C evaporator. If you normally only use the A/C when it's raining, the moisture that has been removed from the air has nowhere to go when the tube is plugged. When sitting in the passenger seat, the tube is approx. by your left foot. If that isn't it, try pouring water by the passenger wiper and see if the water is leaking in from there. This might point to something screwy in the windshield cowl.
Old Sep 23, 2008 | 09:00 PM
Commodore's Avatar
Thanks, outbid81. That was the problem. The drain tube got stuffed back into the drain hole and was draining into the car rather than on the ground. Well, at least the water was very clean so no unpleasant odor ensued. Problem solved!
The Commodore
Old Oct 21, 2008 | 01:00 AM
lexusenthusiast's Avatar
no check the sunroof drain tubes front and rear of the side thats leaking. get a cup of water and pouritfront and rear corners of the track with the sun roof open. if the water drains then they're working. if not un plugthem and vua-la! good luck!
adbbqwi
Jul 22, 2021 09:26 PM
NRWskinny
Dec 3, 2009 03:11 AM
LexusOnDubZ
Sep 27, 2008 02:37 PM
acker1818
Sep 12, 2005 11:48 PM
acker1818
