How to reset "mantainence Required" sign from dashboard?
My 2005 Lexus Es330 is due for Maintenance which cost a ton at the dealerships, so I will get it done at a local store.
How do IRESET the "MAINTENANCE REQUIRED" signfromthedashboard? |
RE: How to reset "mantainence Required" sign from dashboard?
I want to know this too. Anyone?
I just found and instruction for a camry and it worked on my camry. I also have a 2000 ES300, which should work too since it's look/work the same. It's up to you if you want to try it or not.
1- Stick the key in and turn to ON position. 2- click the odometer/trip meter reset pin to odometer and make sure you can see the odometer (the actual miledge of your car, not the trip meters). 3- Turn key to off position 4- press and hold the odometer reset pin 5- turn key to ON position, still hold in the odometer reset pin. You will see the degits on the meter became "--------". Each dash will be blinking and disappeared one by one untill all are done. 6- turn off the key and try to start your car. You should see the maintenant req light went away. |
| All times are GMT -5. The time now is 01:01 AM. |
