How to reset "mantainence Required" sign from dashboard?
Old Aug 10, 2007 | 01:25 PM
jhp012's Avatar
Default How to reset "mantainence Required" sign from dashboard?
My 2005 Lexus Es330 is due for Maintenance which cost a ton at the dealerships, so I will get it done at a local store.
How do IRESET the "MAINTENANCE REQUIRED" signfromthedashboard?
Old Oct 1, 2007 | 01:00 AM
rnl's Avatar
rnl
Default RE: How to reset "mantainence Required" sign from dashboard?
I want to know this too. Anyone?
Old Oct 1, 2007 | 04:13 AM
rnl's Avatar
rnl
I just found and instruction for a camry and it worked on my camry. I also have a 2000 ES300, which should work too since it's look/work the same. It's up to you if you want to try it or not.
1- Stick the key in and turn to ON position.
2- click the odometer/trip meter reset pin to odometer and make sure you can see the odometer (the actual miledge of your car, not the trip meters).
3- Turn key to off position
4- press and hold the odometer reset pin
5- turn key to ON position, still hold in the odometer reset pin.
You will see the degits on the meter became "--------". Each dash will be blinking and disappeared one by one untill all are done.
6- turn off the key and try to start your car. You should see the maintenant req light went away.
93ES300
Jul 29, 2021 12:01 PM
Pang
Jul 27, 2021 07:01 PM
mmercado
Oct 21, 2008 12:24 AM
omarcot
Jul 29, 2006 12:50 PM
