-   -   help with vic light on dash board (https://lexusforum.com/forum/lexus-es-11/help-vic-light-dash-board-45967/)
becca777 Aug 17, 2024 02:23 PM
Hi first time here ! Happy Saturday to all!❤️ Im here in Los Angeles I have a 2007 es and today all of a sudden the check engine ligj vac all the lights came on went to auto zone I don't know how to fix it Help please
Cybersly007 Aug 26, 2024 08:22 PM
Did Autozone check the alternator and battery?
becca777 Aug 26, 2024 08:30 PM
It’s the VSC LIGHT IT CAME UP WITH BANK 2 O2 oxygen sensor left bottom but don’t know
Bank 2 sensor 2 VSC LIGHT CHECK ENGINE LIGHT ALL THE LIGHTS CAME ON AT THE SAME TIME
Cybersly007 Aug 26, 2024 11:08 PM
I’m no expert, only a casual DIY’er. Maybe you’ve already done an online search, but I just did one and found this. https://bryansgarage.com/check-vsc-lexus-es-350/ It details your description fairly well I think. If you know a good honest auto repair shop or guy, I’d think they should be able to fix it. Honestly though, repair parts can be pretty pricey these days, so I’d choose wisely. Two easy fixes were mentioned, you didn’t accidentally turn off the VSC button did you or maybe a loose or faulty gas cap? I know Autozone or other parts stores won’t reset the code, because of liability. However, if you know someone with an OBD2 scanner, the codes could be cleared. If it happens again, then you will have to get it fixed.
Sorry I can’t be of more help, but I hope you can get it taken care of relatively reasonable.
