help with vic light on dash board
Old Aug 17, 2024 | 02:23 PM
becca777's Avatar
Default help with vic light on dash board
Hi first time here ! Happy Saturday to all!❤️ Im here in Los Angeles I have a 2007 es and today all of a sudden the check engine ligj vac all the lights came on went to auto zone I don't know how to fix it Help please
Old Aug 26, 2024 | 08:22 PM
Cybersly007's Avatar
Did Autozone check the alternator and battery?
Old Aug 26, 2024 | 08:30 PM
becca777's Avatar
Default It’s the VSC LIGHT IT CAME UP WITH BANK 2 O2 oxygen sensor left bottom but don’t know
Bank 2 sensor 2 VSC LIGHT CHECK ENGINE LIGHT ALL THE LIGHTS CAME ON AT THE SAME TIME
Old Aug 26, 2024 | 11:08 PM
I’m no expert, only a casual DIY’er. Maybe you’ve already done an online search, but I just did one and found this. https://bryansgarage.com/check-vsc-lexus-es-350/ It details your description fairly well I think. If you know a good honest auto repair shop or guy, I’d think they should be able to fix it. Honestly though, repair parts can be pretty pricey these days, so I’d choose wisely. Two easy fixes were mentioned, you didn’t accidentally turn off the VSC button did you or maybe a loose or faulty gas cap? I know Autozone or other parts stores won’t reset the code, because of liability. However, if you know someone with an OBD2 scanner, the codes could be cleared. If it happens again, then you will have to get it fixed.
Sorry I can’t be of more help, but I hope you can get it taken care of relatively reasonable.
juquan
May 30, 2019 04:28 AM
namthgil2
Sep 21, 2012 12:59 PM
JACKMANBIGDOGS
Sep 17, 2010 04:13 PM
Toeknee
Jul 23, 2007 11:44 AM
jfm
Jan 27, 2006 03:58 PM
