-   -   cylinder 3 misfire? (https://lexusforum.com/forum/lexus-es-11/cylinder-3-misfire-121/)
rasheed52479 Jan 18, 2006 12:04 AM
cylinder 3 misfire?
I have a 1997 lexus es300 with 80k miles. Last week,it started idling low, so I hooked up the OBD2 scanner. It stated cylinder 3 misfire.
I have changed the sparks plugs, spark plug wires, and tested the coil(switched coils). It still idles low and still it states cylinder 3 misfire. I have run out of ideas. Any other suggestions that the problem can be?
jwandhistools Jan 28, 2008 07:39 PM
RE: cylinder 3 misfire?
I have a 200 ES300.
PO306.
same situation as yours.
Flip-flopped 2 coils.
Replaced what seemed like a dead coil.
Same problem.
A month ago the Iridiums plugs were replaced with regular resistor type NGKs.
I am wondering if this caused damage to the ignition system.
I know with older Mitsubishi vans failure to use the Platinum plugs resulted in ignitor failure, or injector problems.
I am going to try putting back the iridiums and see what happens.
96es300 Feb 4, 2008 11:31 AM
Is a 96 OBD2? I need to pull some codes, Im having a poor idle and milage problem and sometimes I can smell fuel but found zero leaks. Could this also be a bad cat or 02's?
